3rd ignition and 2nd accessory
crash2ny
Member - Posts: 9
Posted: May 30, 2003 at 7:42 PM / IP Logged
 i have a 2001 saturn l200 i need help hooking up relays for the 3rd ignition and 2nd accessory wires the remote starter is a hornet 553t if anyone can tell me how to hooks this up help
Platinum - Posts: 12,488
Posted: May 30, 2003 at 7:57 PM / IP Logged
Hook up same as 2 ign diagram here:
Second Ignition relay
crash2ny
Member - Posts: 9
Posted: May 30, 2003 at 8:08 PM / IP Logged
the3rd ignition is(-) and the 2nd acc is (+) is it the same diagram
Posted: May 30, 2003 at 8:14 PM / IP Logged
The lt. green key sense wire ( 3rd IGN ) at the steering column must see a ground during remote start to keep the SERVICE light from coming on. Use the GROUND OUT WHEN RUNNING WIRE from teh RS for this connection. If it doesn't work then you will need a relay to boost the ground signal.  Use the diagram above for the 2nd ACC connection but use a relay ( if necessary ) for the 3rd IGN.
crash2ny
Member - Posts: 9
Posted: May 30, 2003 at 8:20 PM / IP Logged
what would the diagram be for the 3rd ign relay ig needed
Posted: May 30, 2003 at 8:28 PM / IP Logged
Negative to Negative Relay Diagram
crash2ny
Member - Posts: 9
Posted: May 30, 2003 at 8:39 PM / IP Logged
can you hook up both of these relays to the blue/black 3rd ign wire one 553t remote starter or how does that work
Posted: May 30, 2003 at 8:57 PM / IP Logged
Yes, you can hook up the (-) trigger wire to engage both relays.
Thursday, February 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
