Viper 5806V, DBALL2/T-Harness 2009 Jeep Liberty
chrisjcline
Member - Posts: 6
Posted: December 31, 2016 at 2:18 PM / IP Logged Link to Post Post Reply Quote chrisjcline
Does anyone know if I use the DBALL2 with T-Harness if I still need to connect the remote start harness from the Viper side? Yes, I am new but stubborn to have the install done when I can simply learn.
If someone could give me a high overview of the connections, it would be appreciated.
Viper 5806V Remote Start and Alarm.
DBALL2 with firmware pre-loaded for 2009 Jeep Liberty.
T-Harness for said Jeep.
I know I will need to connect the T-Harness to DBALL2, then DBALL2 to the Viper via D2D.
smokeman1
Platinum - Posts: 1,589
Posted: December 31, 2016 at 7:05 PM / IP Logged Link to Post Post Reply Quote smokeman1
Link to a 2010 Liberty I did. Did it D2D. No harness though.
https://www.the12volt.com/installbay/forum_posts.asp?tid=135101
Bulldog Security list the liberty from 2008-2012 as the same for wiring.
http://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.aspx
chrisjcline
Member - Posts: 6
Posted: January 02, 2017 at 3:24 PM / IP Logged Link to Post Post Reply Quote chrisjcline
Afternoon,
I put together a crude diagram for the Viper 5806V + dball2 with Immobilizer Harness for a 2009 Jeep Liberty Limited Edition.
I am stuck on trying to figure out where all of the 10-Pin connectors go? I am also not sure if I need to even connect the 10-Pin (10 Pink) wire to the Ignition switch since it is connected to the dball2 ignotion?
Viper 5806V, DBALL2/T-Harness 2009 Jeep Liberty -- posted image.
smokeman1
Posted: January 02, 2017 at 5:09 PM / IP Logged Link to Post Post Reply Quote smokeman1
It states on the diagram, Black 10 Pin connector, Do Not Connect
chrisjcline
Member - Posts: 6
Posted: January 02, 2017 at 5:37 PM / IP Logged Link to Post Post Reply Quote chrisjcline
My mistake for not being clear. I was referring to the 10-Pin coming from the Viper.
smokeman1
Posted: January 02, 2017 at 7:27 PM / IP Logged Link to Post Post Reply Quote smokeman1
Looking at the diagram, it looks like the only wires from the Heavy Gauge harness will be the Pink Ignition to the DBALL and Red to 12 volt constant.
chrisjcline
Member - Posts: 6
Posted: January 07, 2017 at 4:47 PM / IP Logged Link to Post Post Reply Quote chrisjcline
I wanted to thank everyone for helping me out. I was able to install and get the remote start working. However, I do have one last question. Once I remote start the car I am unable to turn off the car by sticking in the key and turning it off. What did I miss in the programming or wiring?
geepherder
Platinum - Posts: 3,668
Posted: January 07, 2017 at 5:57 PM / IP Logged Link to Post Post Reply Quote geepherder
Stepping on the brake should kill it. If this signal is not supplied by the DBALL2 (not sure if it is), you can connect the brown brake wire in the Viper harness to the switch above your brake pedal.
