1994 silverado 5806 viper install
craig harris
Posted: March 21, 2017 at 3:44 PM / IP Logged Link to Post Post Reply Quote craig harris
cant figure out why im unable to access the menus on viper5806. valet mode turns on and off, but keep getting manual trans mode with 7 flashes . try to go to menu 3 and it does nothing.
classicman
12volt burnout
Posted: March 30, 2017 at 8:20 AM / IP Logged Link to Post Post Reply Quote 12volt burnout
Do you have door trigger ? Prob not
craig harris
Posted: March 31, 2017 at 5:04 PM / IP Logged Link to Post Post Reply Quote craig harris
You are correct on the door trigger. Thought I had to connect through a relay. Hooked it directly to the door trigger wire and bingo,problem solved. Thanks for replying.
classicman
Monday, December 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
