RHD IS250 with Viper 4105V
chardc
Member - Posts: 40
Posted: April 14, 2017 at 2:04 PM / IP Logged Link to Post Post Reply Quote chardc
Hey All,
Its been a very long time since I have done any postings here - I hope all is well.
I am trying to install the viper 4105v on my Lexus IS250 (2006) and I have all the wires connected, but the car fails to start.
The error received from the Viper 4105v diagnostics suggests its low voltage or rpm (3 Flashes) and I believe this is associated with the TACH signal.
I truly believe that this is the case, because the meter reads a little over 6V and I am using the wire from the OBD diagnostic connector.
Alternatively, I have the option of using the ignition or injector to obtain the TACH, but before I do so, can anyone suggest if there is something wrong other than what I have observed in all my test.
Wiring Info (www.S P A M.com)
2006 Lexus IS250 Remote Starter Wiring Diagram
Vehicle Battery Positive Wire (+): Orange (Vehicle Battery Positive Wire Location: At Power Source ECU Module Behind Glove Box) <--- no orange wire ---> black wire instead and was found via (www.wirecolors.com) <--- 4105v H2/4 and H2/6
Vehicle Ignition Wire (+): Light Green (Vehicle Ignition Wire Location: At Power Source ECU Module Behind Glove Box) <--- 4105v H2/1
Vehicle Second Ignition Wire (+): Pink (Vehicle Second Ignition Wire Location: At Power Source ECU Module Behind Glove Box) <--- 4105v H2/5
Vehicle Accessory Wire (+): Light Green (Vehicle Accessory Wire Location: At Power Source ECU Module Behind Glove Box) <--- 4105v H2/3
Automobile Engine Starter Wire (+): Black (Automobile Engine Starter Wire Location: At Power Source ECU Module Behind Glove Box) <--- 4105v H2/2
Car Tachometer Wire (-): White Car (Tachometer Wire Location: At Vehicle Data Link Connector) <--- 4105v H3/2
Car Parking Lights Wire (+): Yellow (Car Parking Lights Wire Location: At Vehicle Fuse Box on Driver Side) <--- 4105v H1/9
Car Horn Wire (-): White (Car Horn Wire Location: In Harness at Steering Column) <--- 4105v H1/6
Car Ground: Chassis <--- 4105v H1/8
Other Notes
DEI 555X is partially wired, but not connected
4105v door lock and unlock are wired and functional
Regards,
ChardC
chardc
Member - Posts: 40
Posted: April 14, 2017 at 8:57 PM / IP Logged Link to Post Post Reply Quote chardc
Okay, I had one more check to do.
During an attempt to remotely start the car, the TACH reads moves from 0.001 to 0.028 on the multimeter.
If the car is started via the push-to-start button, the wire reads 6V.
Could this be a problem on the remote start itself?
Regards,
ChardC
chardc
Member - Posts: 40
Posted: April 15, 2017 at 8:44 AM / IP Logged Link to Post Post Reply Quote chardc
Problem solved!
This is incorrect, the wire reads a constant 12V with the car off - I have no idea how I missed that yesterday. The correct wire for the starter is a light blue wire on the Power Source ECU Module (PIN 17) and the voltage was measured correctly moving from ACC (12v)-IGN(12v)-STR (12v only to start)
However, whilst I am able to start the car, the immobilizer (DEI 555x) bypass isn't fully setup and I must be in the car for it to start remotely.
I suspect this is due to key sense for the push-to-start / immobilizer.
Outside of the vehicle, the car is constantly cranking...but never starts.
ChardC
