08 Silverado remote start stopped working
sgarcia1212
Member - Posts: 40
Posted: April 29, 2017 at 10:39 PM / IP Logged Link to Post Post Reply Quote sgarcia1212
Hi all, remote start stopped working after about a year of being installed.
Truck info:
-2008 Silverado Duramax 3500
-Python remote start (Python 5206)
-Bypass module (DBALL2).
Symptoms:
-No starter cranking (starter never engages.
-Lights on dash don't turn on when remote start is activated (accessory pwr)
Shout down diagnostics indicates 3 flashes (Low or no RPM)
I can hear relay activity inside the remote start unit when remote start is activated.
Please let me know if additional info is needed.
Any advice/help will be appreciated.
Thanks in advance.
sgarcia1212
tdbaker021
Copper - Posts: 98
Posted: April 29, 2017 at 11:22 PM / IP Logged Link to Post Post Reply Quote tdbaker021
Did you check the tach wire??
sgarcia1212
Member - Posts: 40
Posted: April 29, 2017 at 11:24 PM / IP Logged Link to Post Post Reply Quote sgarcia1212
Tach wire is not connected.
Is set up as virtual tach.
sgarcia1212
tdbaker021
Copper - Posts: 98
Posted: April 30, 2017 at 2:52 PM / IP Logged Link to Post Post Reply Quote tdbaker021
I would either try to reprogram the bypass or connect the tach wire and see if that solves your problem.
sgarcia1212
Member - Posts: 40
Posted: April 30, 2017 at 4:08 PM / IP Logged Link to Post Post Reply Quote sgarcia1212
I did reprogram the bypass with the latest firmware and no change.
Older firmware was GM6. the latest is GM11, both of these are wired differently according to the installation guide.
Is there a way to go back to GM6 firmware or I'm stuck with GM11?
Thanks.
08 Silverado remote start stopped working -- posted image.
sgarcia1212
tdbaker021
Copper - Posts: 98
Posted: May 02, 2017 at 9:57 PM / IP Logged Link to Post Post Reply Quote tdbaker021
Thanks.
Did you run into this problem before or after updating the firmware? I think you can go back to the GM6 but I'm not 100% sure...
sgarcia1212
Member - Posts: 40
Posted: May 02, 2017 at 11:26 PM / IP Logged Link to Post Post Reply Quote sgarcia1212
The issue started before updating firmware.
sgarcia1212
tdbaker021
Copper - Posts: 98
Posted: May 03, 2017 at 12:24 PM / IP Logged Link to Post Post Reply Quote tdbaker021
I would either wire the RS according to the new firmware or try and downgrade the FW. It's going to be hard to figure out what is going on until that is done.
sgarcia1212
Member - Posts: 40
Posted: May 07, 2017 at 9:01 AM / IP Logged Link to Post Post Reply Quote sgarcia1212
Do you know how can I downgrade the firmware?
sgarcia1212
Sunday, December 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
