2002 dodge dakota
amador
Copper - Posts: 108
Posted: June 01, 2003 at 4:25 PM / IP Logged
hello guys i am looking for a alarm wire diagram for a 2002 dodge dakota any and all help welcomed thanks
draasch
Gold - Posts: 2,172
Posted: June 01, 2003 at 10:21 PM / IP Logged
Make:   Buick
Model: Century
Year:    1984-93
This Database Was Last Updated On:    10/7/02
Index #: 6354
Alarm
Constant 12 volts RED AND RED IGNITION SWITCH HARNESS
Ignition 12 volts PINK IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light WHITE (-) PIN SWITCH OR AT COURTESY LIGHT
Trunk Pin Switch BLACK/ ORANGE (-) SWITCH OR REAR BODY HARN.(WAGON ONLY)
Parking Lamp BROWN (+) HEADLIGHT SWITCH
Power Lock LIGHT BLUE DRIVER KICK PANEL # 202
Power Unlock BLACK DRIVER KICK PANEL # 202
#202- See Positive Pulse Door Lock Diagram.
Remote Start
Tach Signal BLACK/ GRAY AT COIL #239
Ignition #2 DARK GREEN/ RED IGNITION SWITCH HARNESS (TRANS)
Ignition #3 BLACK/ ORANGE IGNITION SWITCH HARNESS (HEAT CONT)
Accessory DARK/GREEN & RED / WHT IGNITION SWITCH HARNESS (BLOWER)
Neutral Safety
Brake Light WHITE/ TAN (+) ABOVE BRAKE PEDAL
Reverse Light VIOLET/BLACK (+) LEFT FRONT OF ENGINE 28 PIN CON,PIN 2
Rear Window Defrost
** See TECH NOTES For Additional Information On Ignition Switch Layout. #235 - See Powering Extra Ignitions Diagram.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
