dball2, 2006 Toyota Corolla
ricardoboston
Copper - Posts: 268
Posted: September 26, 2017 at 8:27 PM / IP Logged Link to Post Post Reply Quote ricardoboston
hey there its just a weird problem with a dball2 I have done a 2006 Toyota Corolla using a dball2 and an avital 5303 everting works just fine the only thing wrong is on the dball2 programming it blinks green and them it should turns off as the programming method says but it does not turns itself off instead the green light stays on all the time , remote start works fine but if disconnect the battery and get connected again it won't start the engine anymore need to reprograming with the key ,the only thing I did not connect was the auto lights shuts off and the ground number 2 on the dball2 any ideas if it hurts the car stays on or anything I should do different please thanks
