remote start yellow wire
peet1212
Posted: June 02, 2003 at 6:32 PM / IP Logged
2003 s-10 blazer and I can't find the yellow starter wire.
Sound Pressure
Silver - Posts: 711
Posted: June 02, 2003 at 6:34 PM / IP Logged
Did you follow the heavy gauge wires leading up the steering colum?
Sound Pressure
peet1212
Posted: June 02, 2003 at 6:41 PM / IP Logged
I have followed all the wires up the steering colum
NowYaKnow
Gold - Posts: 1,217
Posted: June 02, 2003 at 7:23 PM / IP Logged
Remove the bottom underdash panel. You can leave the panel that hold the park brake release in place if you want. Near your underdash light on the drivers side will be a big black plug with a bunch of wires running into it. On the right side of that connector will be a thinner white and yellow wire. These are your ignition 2 and starter wire, both of which you need for a remote start. They are NOT real thick like the ignition 1 (pink), power (red, RED / white), and the orange heat/ac wire. Hope that helps. Later,
Mike
peet1212
Posted: June 08, 2003 at 7:39 AM / IP Logged
Thanks for the info,I was looking for heavy gage wires for ing2 and starter.
Works good.
Thanks Mike.
Pete
