2013 infiniti g37 fortin thar-nis1 door pins bcm
johnwohl
Member - Posts: 20
Posted: October 29, 2017 at 1:50 AM / IP Logged Link to Post Post Reply Quote johnwohl
hello there all. i figured I would ask before I break one of these things.
Working on my 2013 Infiniti g37 sedan and a Fortin EVO-ONE with the THAR-NIS1 t-harness.
The directions say to transfer the prepinned ends from the green and green/white door lock/unlock to the purple and purple/white arm/disarm wires so I did that. I ran into a problem when, try as I might, these pins will not go into the green bcm connector all the way. I see that they are slightly keyed to go in one way but they stop about half way down the connector. If I push any harder it will bend and eventually break. Am I supposed to open the connector or something? How would I do that? None of the tutorials I've found go into any detail about how adding a previously empty pin is done. Maybe I'm just doing it wrong.
Platinum - Posts: 7,828
Posted: October 29, 2017 at 4:19 PM / IP Logged Link to Post Post Reply Quote kreg357
The way I do those wires at Nissan BCM empty pins is :
1. Strip about 3/4 inch of insulation from the needed wire.
2. Use your fingers to put a real tight twist on the exposed wire strands.
3. Insert that wire end into the empty socket, press it in as deep as possible with a little force.
4. Secure that wire with tie wraps or quality electric tape or both to an adjacent wire or two.
You could try to find a connector repair kit at the dealer to get a spare pin or get that type connector off a wreck at a salvage yard to get a few spare pins.
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
