Scytek LED stays on not in valet
eugenile
Member - Posts: 8
Posted: November 07, 2017 at 12:40 PM / IP Logged Link to Post Post Reply Quote eugenile
hi yall, I have a vehicle equipped with a scytek 5000RS. everything works fine but I found it odd the LED indicator stays on. It has 2 leds, the ones built into the astra extended antenna for the system and a standalone blue led. they seem to be wired together because they function identical. flash at same time etc.
Like I said the system functions normally. once key is turned on ignition the led lights go off. when during the programming and setup it flashes as its suppose to. just as soon as i take out key lights instantly go on.
is this normal for the scytek? i just dont want this to be the cause of my battery drain.
