Viper remote start install 2006 Mustang wiring
toothdock
Member - Posts: 6
Posted: January 31, 2018 at 1:39 PM / IP Logged Link to Post Post Reply Quote toothdock
Hi guys,
Gonna attempt an install of a Viper 4105 -- on a 2006 Ford Mustang Automatic V6 (without the factory alarm option)
Here is the diagram that I have come up with so far, I need some help and someone to check it:
Primary Harness
Light green black (factory alarm disarm) - NOT USED
Green white (factory alarm rearm) - NOT USED
Yellow (ignition to alarm) - NOT USED
White blue (activation input) - ??? I don’t know what this is
Orange (ground when locked/anti grind) - ?????? I don’t know where to connect this
Brown (horn out) - Dark blue, SJB blue 52 pin (#39), negative wire
Red white (trunk release) - White purple, SJB black 52 pin (#13), negative wire
Black (chassis ground) - Chassis
White (light flash output) - Black light green, blue 52 pin (#31), negative wire
Remote Start Harness
Black white (parking brake input) - Light green, SJB gray 36 pin (#16),
Violet white (tachometer input) - ?????? I don’t know where to connect this
Brown (brake shutdown input) - ????? I don’t know where to best connect this
Gray (hood pin switch) - supplied hood pin
Blue white (rear defogger out) - Pink, SJB blue 52 pin (#18)
Relay
Red (large 12v in) - Light green purple at ignition switch (Is this right?)
Pink white (second ignition output) - NOT USED
Orange (accessory output) - Black pink at ignition switch
Purple (starter output) - Dark green at ignition switch
Pink (Ignition in/out) - White yellow at ignition switch
Satellite - Not used
Door lock
Light blue (unlock) - Dark blue light green, SJB black 26 pin (#3), type B wire
Green (lock) - White purple, SJB black 26 pin (#1), type B wire
I also have a PKALL that I will be hooking up
