2003 Honda Accord / Clifford Matrix RS2
Welcome Guest :)
DracosIgnis
Member -
Posted: June 04, 2003 at 11:26 AM / IP Logged
After installing a Clifford Matrix RS2 in a 2003 Honda Accord I've got a few questions I'm hoping someone can help with. Someone who has actually worked on a 2003 accord, only because wire colors posted on the net seem to be incorrect. I have found the same wiring color sheets at numerous website. Unfortunately, most of the color seem to be wrong, and it took hours of probing to find each wire (at which I will list once completed.) Question #1 - Has anyone found the door trigger wire, without running a wire to each door? The problem if using the dome light... after canceling a remote start, the dome light comes on, and sets the alarm off. (happens whether the igintion controlled dome light feature is on or off on the clifford unit, since honda built in the ignition off, domelight on feature also.) Question #2 - After using two different Clifford main head modules to eliminate that being the problem, if I remote pop the trunk, and try then try to enter the vehicle, the alarm will disarm, but the doors will NOT unlock. I can disarm 30 seconds or 3 minutes after opening the trunk, but still no unlock. Very strange! Any help would be greatly appreciated, as I'm an ordinary person, not a pro installing this system. Other than the two problems above, the alarm works great, and seems to be an awesome product. Mike
Moderator -
Posted: June 04, 2003 at 3:20 PM / IP Logged
Hey Mike, can you please post the colors that you have ? This will help us help you find the proper colors.
Thursday, November 13, 2025
• Copyright © 1999-2025 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
