Viper 5706v, 2005 Ram Remote Start Not Working
mikelecookman
Posted: July 23, 2018 at 12:09 PM / IP Logged
Hoping someone can verify my install. I believe the unit is bad as the unit isn’t allowing any bypass from the ignition. In otherwords when the key is turned on, nothing happens. No lights radio or anything. The unit has power going in from the ignition but nothing coming out, unless power is applied to the “pink/blk flex relay” wire. Also the “command center” does nothing. It will blink when armed, but will not enter Valet mode or programming mode. Alarm works fine otherwise. Arms, locks/unlocks, flashes lights Ect. But Remote start does nothing but flash 7 times. Menu cannot be accessed for man/auto switch.
My wiring is as Follows:
Harness 1 6pin.
Red— 12v+ constant from Red Ignition wire.
Black— Solid chassis’s ground
Brown— Siren +
White/Br & White—-Parking light connection. via Bulldog security with required resistor.
Orange—-Not used.
Harness 2 (24 pin) I’ve only used the required wires.
12: Violet/ White. Tach input. (Pin 24 in the 60 pin plug on pcm. It’s a Diesel.
13: Blk/wh. NS/PB. (Solid chassis ground)
15: Green. - Door input. Hooked up via Bull dogs diagram with All 4 doors and diodes. I’ve also tried to ground this wire directly to see if it would do anything different. It doesn’t. Still acts the same.
20: Brown brake input: Connects to brake light switch Whit/tan.
Remote Start Harness 10 wire.
1:NC
2: Red/Blk. Constant 12v+ from ignition red.
3: pink/Blk. Flex relay input. Not used....However if power is applied to this wire, the truck lights up as it would if you turned on the ignition.
4: Pink /White. Ignition 2 Truck side.— Wire color pink/lt grn.
5: Red. Ignition 1 input. Key side—Wire color Pink/White
6: Green: Starter OP. Yellow truck side
7: Violet: Starter IP. Yellow key side
8: Orange: Acc Op. spliced into Blue ignition wire.( Blower motor)
9: Red/White. IGN 2 input from Key side Pink/lt green.
10: Pink. Ignition 1 output. Truck side pink/White.
So how I connected these wires is as follows.
On the Red supply wire on the truck, I spliced into it with #2 Red/Blk.
Ignition 1 Pink/White. I cut it, and connected Red #5. Key side.
Ignition 1 Pink/White Truck side is connected to#10 Pink.
Ignition 2 Pink/ Lt Green is Cut and Connected Key side to #9 Red/Wh.
Ignition 2 Pink/Lt Green is Connected Truck side to #4 Pink / White
Is this correct? Thanks in Advance!!
mikelecookman
Posted: July 23, 2018 at 12:11 PM / IP Logged
I’m a DA.. After typing this all out I realized what happened. All connections should’ve been spliced not cut.. Works like a dream, not sure how I overlooked that..
