2000 Mitsubishi Lancer / Mirage Door Locks w/ Avital 3100LX
panchotealarga
Posted: August 08, 2019 at 1:30 PM / IP Logged Link to Post Post Reply Quote panchotealarga
Hello community!
Im working on my 2000 Mitsubishi Lancer GLXi (Mirage based lancer, not even close to an EVO)
this is the car
I bought the best seller Avital 3100LX (the one without siren) on amazon
almost done seting up, but Im having difficulties with the remote door lock/unlock feature.
From factory the car locks/unlocks 4 doors with key from outside and from drivers and co-pilot door lock/unlock lever inside
I removed the cover of the drivers door and found that the system is mechanichal from the lever to the lock, from there I have 5 cables going towards the fusebox below the steering wheel
Black - Ground
Red/White   - +12v continuos on lock
Red - +12 continuos on unlock
Blue/Red - +12v pulse on lock
Blue/Black - +12v pulse on unlock
What type of door lock system is this?
I tried using Blue/red and Blue/black connected to the alarm thinking the module would send those 12v pulse, but I got nothing
Should I be using this wires or trying to find something behind the fusebox? I already got the relay idientified
One other thing the Starter Interrupt seems to do nothing when alarm is armed. I cant start the engine anyway
I double checked the Constant 12v+ , Starter and Ignition wirings are good. If I remove the last two from the module I cannot crank the engine, so it seems its the module?
Thank You!
iskidoo
Silver - Posts: 1,046
Posted: August 08, 2019 at 8:27 PM / IP Logged Link to Post Post Reply Quote iskidoo
I can’t find a 2000 Lancer in the wiring database but you can try this one for the Mirage. Says type B and the wire colors and location are listed.
2000 Mitsubishi Mirage
Steve G
