Pro Start 3200, Keeps Cranking But Won’t Start With Remote
khush
Member - Posts: 7
Posted: October 17, 2022 at 12:26 PM / IP Logged Link to Post Post Reply Quote khush
Hi
I installed pro star 3200 years ago on 2001 civic all was going good but but now what happened when I tries to remote start car just keep cranking but don’t start .
Other hand when I keep the key in ignition or tape on ignition or place on ignition it starts fine from remote.
How to fix it ?
I checked it’s not in valet mode tech programming is good .
Looking forward for help
Platinum - Posts: 13,722
Posted: October 17, 2022 at 6:10 PM / IP Logged Link to Post Post Reply Quote i am an idiot
What did you use for transponder bypass? If a key in a coffin, make sure the key is properly lodged in the coffin. Make sure it is still receiving ground from the rem start unit.
silvercivicsir
Copper - Posts: 416
Posted: October 18, 2022 at 4:34 PM / IP Logged Link to Post Post Reply Quote silvercivicsir
it's your immobilizer.. how did you bypass it? did the battery die recently? might need to relearn the bypass, or like the reply, check the key in the box
khush
Member - Posts: 7
Posted: October 18, 2022 at 11:07 PM / IP Logged Link to Post Post Reply Quote khush
Thanks a lot
You are right it was not on right place.
Big relief :D
I am an idiot didn’t thought about it a sec.
Wednesday, October 8, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
