Viper 4806 Failure? 2005 Chevrolet Silverado 2500HD
titaniumman
Posted: January 31, 2023 at 8:35 AM / IP Logged Link to Post Post Reply Quote titaniumman
2005 Chevy 2500 HD (no smart key) with Viper 4806 installed for about 5 years. Professional installation and has worked flawlessly until yesterday. Attempted to remote start the vehicle without realizing the battery was dead due to cold weather. Jump started the vehicle and now the remote start won't work. Tried pairing the remote with the control unit. Control unit LED does not flash and the horn does not honk. I've checked the 10 amp fuse located in the Viper box under the dash and also the cluster of three 20 amp fuses I located in the wiring. I can't see anything else obvious and simple to check. Does anyone have any ideas about what else to check? Is it fried? Thanks in advance.
Rusty but functional...
silvercivicsir
Copper - Posts: 416
Posted: January 31, 2023 at 9:07 AM / IP Logged Link to Post Post Reply Quote silvercivicsir
try power cycling the viper unit (unplug the 8 pin connector with the power and ground). and check to make sure the viper unit is getting power, either a test light or multi meter.
titaniumman
Posted: January 31, 2023 at 10:57 AM / IP Logged Link to Post Post Reply Quote titaniumman
Thanks, I'll give that a try.
Thursday, February 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
