If you wish to post a reply to this topic, you must first login.
If you are not already registered, you must first register.
Saturday, January 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
1. Is the reason the remote start not working because the tach and brake switch arnt wired ?
2. When they say brake switch is it the parking brake or brake
3. There is a lot of output wires not connected. Were they replaced by the Xpress bypass
https://www.the12volt.com/installbay/forum_posts.asp?tid=137181
Tachometer RED / white to WHITE/ green ac cluster, wh 40P plg, pin 30 or ECM bhnd glv box, wh35P plg(B), pin15
Parking Brake gray - BIU right of steering column, white 35 pin plug (C), pin 32
Thank you to anyone that helps!
