1996 Toyota 4Runner, Parking Light Not Working On Compustar CMX
choleaoum
Copper - Posts: 81
Posted: October 06, 2024 at 3:30 PM / IP Logged Link to Post Post Reply Quote choleaoum
Hello, I am having issues with my parking lights flashing when arming and disarming. I am using the red white wire found in my steering column. I also tested it by grounding it to chassis and the lights turn on. I also tested the voltage from the wire coming from the brain with a multimeter and it is also showing 12 volt on disarm/arm.
When I hook the wire up, I only see it going up to 0.4 v about 2-3 times and then back to 0. When they are not hooked up then they will both go to 12volt using the same ignition wire for power.
lee.lopez
Copper - Posts: 302
Posted: October 06, 2024 at 5:26 PM / IP Logged Link to Post Post Reply Quote lee.lopez
If I understand you correctly, you have verified the factory red/white parking light wire is negative switched.
If you're using the green/white parking light wire from the CMX, it outputs 12 volts positive, so this won't make your lights flash.
The easiest solution would be to connect to the green factory parking light wire at the white connector under the fuse box.
Otherwise you could either use a relay to convert to a negative pulse, or program a POC on the CMX to 2nd light.
choleaoum
Copper - Posts: 81
Posted: October 06, 2024 at 11:48 PM / IP Logged Link to Post Post Reply Quote choleaoum
I am using the negative (green/white) wire from the compustar cmx brain to the (-) parking switch on the vehicle. It's 250ma negative output which I believe isn't strong enough to turn the parking lights on. I believe I would have to uses the relay to drive this wire more. What do you think?
chev104275
Gold - Posts: 1,436
Posted: October 07, 2024 at 4:22 AM / IP Logged Link to Post Post Reply Quote chev104275
I've never done this truck but I would use a meter to find out how much current it takes to activate that wire. I would guess its running from the switch to a factory relay it should draw somewhere around 150mA. If it runs directly to the lights it would draw somewhere around 8-10 Amps depending on how many lights are attached to it.
lee.lopez
Copper - Posts: 302
Posted: October 07, 2024 at 8:57 AM / IP Logged Link to Post Post Reply Quote lee.lopez
If it were me, I would probably use the positive parking light output from the CMX to the positive parking light wire in the vehicle.
choleaoum
Copper - Posts: 81
Posted: October 07, 2024 at 9:30 AM / IP Logged Link to Post Post Reply Quote choleaoum
Looks like I'm going this route, it's unfortunate because I've already depinned it from the large harness. I didn't think it was going to give me such an issue.
lee.lopez
Copper - Posts: 302
Posted: October 07, 2024 at 10:55 AM / IP Logged Link to Post Post Reply Quote lee.lopez
I see. You could see if the negative green/white triggers a relay. If it does you could use that relay to provide a stronger ground to the factory red/white.
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
