Compustar CM900AS, Update Firmware
britton0055
Posted: November 16, 2024 at 10:04 AM / IP Logged Link to Post Post Reply Quote britton0055
I have the cm900as I want to update the firmware and I bought the usb hub for my Mac but no matter what I do or website I go to I keep being told I can’t get am account to flash unless I am a installer from a actual business. Is there any way I can do it myself thanks.
drunktiger
Member - Posts: 6
Posted: November 19, 2024 at 4:46 PM / IP Logged Link to Post Post Reply Quote drunktiger
Have you downloaded the Weblink Desktop Program from https://www.weblinkupdater.com/weblinkdesktop/en? I was able to login using an idatalink maestro account and update the firmware for my CM900AS and Blade-AL. You should be able to create an account from here https://www.idatalink.com/weblink/. It won't give you installation instructions for the CM900AS (it does for the Blade-AL Immobilizer) but it should allow you to update the firmware and choose your programming options.
Wednesday, April 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
