expidetion alarm
rickgood
Member - Posts: 38
Posted: June 18, 2003 at 7:26 PM / IP Logged
Hi guys
  I am about to install a  Clifford alarm in a 2003 Ford Expedition.I was able to locate a wiring diagram for a 2000.  Does anyone know if there has been any changes.Will i be required to install additional relays for the door locks. Any helpful information would be appreciated.
                                 Thanks Rick
draasch
Gold - Posts: 2,172
Posted: June 19, 2003 at 1:37 PM / IP Logged
Make:   Ford
Model: Expedition
Year:    2003
This Database Was Last Updated On:    6/9/03
Index #: 7143
Alarm
Constant 12 volts GREEN/ VIOLET IGNITION SWITCH HARNESS
Ignition 12 volts BLUE/GREEN IGNITION SWITCH HARNESS
Starter RED / BLUE IGNITION SWITCH HARNESS
Dome Light BLACK/ LT BLUE (+) DRIVER KICK PANEL
Trunk Pin Switch WHITE/ VIOLET (-) VSM *
Parking Lamp BROWN (+) DRIVER KICK PANEL-GREY 66 PIN CONN
Power Lock PINK / YELLOW DRIVER KICK PANEL OR VSM* #201
Power Unlock PINK/GREEN DRIVER KICK PANEL OR VSM*
* Vehicle Security Module (VSM) Located Under Dash In Passenger Side Kick. #201- See Negative Pulse Door Lock Diagram
Remote Start
Tach Signal PINK/WHITE PCM- 46 PIN (MIDDLE) CONNECTOR * #239
Ignition #2
Ignition #3
Accessory BLACK/ GREEN IGNITION SWITCH HARNESS
Neutral Safety WHITE/ BLACK (-) PCM 30 PIN (TOP RIGHT) CONNECTOR *
Brake Light LIGHT GREEN (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light BLACK/ PINK (+) GREY 66 PIN CONN - LOWER DRIVER KICK
Rear Window Defrost BROWN / LT BLUE (+) GREY 6 PIN CONNECTOR IN PASS KICK **
*Powertrain Control Module Located-Passenger Rear Firewall Of Engine Compart. ** High Amprage Circuit- Feed to Window Grid! #239- See Immobilizer Bypass Diagra
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Monday, March 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
