starter output connection...
sufferrar
Copper - Posts: 190
Posted: June 30, 2003 at 6:03 AM / IP Logged
I have a 725t hornet and i'm planning to upgrade to a hornet 554t . this has remote start and i need to find out if the starter output for remote start goes before or after the starter kill relay .The installation manual says that it also has the antigrind feature which suggest that it goes before the relay but in the trouble shooting section of the manual it say that is the solution for no crank is to make sure the starter output for remote start is on the starter side ( which suggest that it is on the starter side .. which side is it on??? )
"I'm So Loud It Hertz"
drvnbysound
Silver - Posts: 289
Posted: June 30, 2003 at 9:47 AM / IP Logged
If you are going to install an alarm with remote start and also have the starter kill relay, you will need to cut your starter wire. After cutting you will have one side which is on the ignition switch side, and the other which is on the starter side. You will need to connect the starter wire from the alarm (I believe it will be brown)... to the starter side of the cars starter wire along with one of the orange wires from the starter kill relay. Then you connect the car's ingition switch side of the starter wire to the other orange wire from the relay. That should answer all your questions.
sufferrar
Copper - Posts: 190
Posted: June 30, 2003 at 10:09 AM / IP Logged
I have installed the starter kill already and it works . what i need to know is where do i put the remote start(crank) wire? does it go on the starter side or the ignition side?
Saturday, April 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
