parking lights don't flash anymore
kenshin
Member - Posts: 12
Posted: July 24, 2003 at 2:58 PM / IP Logged
I own a 95 Civic 4dr, that had an aftermarket Audiovox alarm, dunno which model,  installed by a shop long time ago  and after I got into an accident 2 months ago, when i hit the k/e, the alarm still chirps, my door still unlocks, but the parking light doesn't flash anymore.  What could cause this?  I have no idea where anything for the alarm is installed.
alanleary
Member - Posts: 28
Posted: July 24, 2003 at 3:01 PM / IP Logged
It sounds like an internal relay...probley not much hope for it...you may want to see if you can tack it apart an replace the relay...but that is just a suguestion...
dogsalan1
kenshin
Member - Posts: 12
Posted: July 24, 2003 at 3:07 PM / IP Logged
how'd i do that? i have no idea how the alarm was hooked up.  where and what would i be looking for?
draasch
Gold - Posts: 2,172
Posted: July 24, 2003 at 3:18 PM / IP Logged
first i would check the inline fuse for the light flash output from the alarm.
look under the driverside dash for the alarm. most alarms use a white wire for the parking lights. you will know it when you see it. check that first, it might just be blown
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
alanleary
Member - Posts: 28
Posted: July 24, 2003 at 3:56 PM / IP Logged
didnt think of that ...that is your best bet>>
dogsalan1
kenshin
Member - Posts: 12
Posted: July 24, 2003 at 4:38 PM / IP Logged
bingo! i found a blown inline fuse on the RED / white wire from the alarm box, took me a while to even find the box, it wasn't mounted anymore (dunno why) gonna head out to buy the fuse.  let ya know if works when i get back. thanks a bunch.
kenshin
Member - Posts: 12
Posted: July 24, 2003 at 5:25 PM / IP Logged
sweet mama, you guys rock! i can find my car blinking again in the giant parking lots of nyc..!
