Lexus LS430 rs
csorb
Copper - Posts: 317
Posted: August 06, 2003 at 12:18 PM / IP Logged
Hi. Has anyone done one of these. Putting in a remote starter and can't seem to get the right wire colors
Platinum - Posts: 12,488
Posted: August 06, 2003 at 1:29 PM / IP Logged
|              12V|BLACK/ red           |+  |ignition harness            |
|          STARTER|BLACK/ white         |+  |ignition harness            |
|         IGNITION|black               |+  |ignition harness            |
|  SECOND IGNITION|RED / white           |+  |ignition harness            |
|        ACCESSORY|WHITE/ green         |+  |ignition harness            |
|       POWER LOCK|RED / black           |-  |driver door ECU in the door |
|     POWER UNLOCK|BLACK/ green *5      |-  |driver door ECU in the door |
|       LOCK MOTOR|brown               |   |driver door ECU in the door |
|     UNLOCK MOTOR|yellow              |   |driver door ECU in the door |
|    DISARM DEFEAT|                    |   |                            |
| PARKING LIGHTS +|*1                  |   |                            |
|       HEADLIGHTS|RED / yellow          |-  |drivers kick panel *4       |
|     DOOR TRIGGER|PURPLE / white        |-  |ignition key cylinder light |
| DOME SUPERVISION|comes on with unlock|   |                            |
|  TRUNK/HATCH PIN|blue                |-  |trunk pin switch            |
|         HOOD PIN|GREEN / WHITE         |-  |hood pinswitch in latch     |
|TRNK/HTCH RELEASE|purple              |-  |release switch              |
|  FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
| DISARM NO UNLOCK|GREEN/ red           |-  |trunk key cylinder          |
|       TACHOMETER|BLACK / YELLOW        |   |data link connector *2      |
|      SPEED SENSE|PURPLE / white        |   |instrument cluster *3       |
|       BRAKE WIRE|GREEN/ orange        |+  |brake pedal switch          |
|     HORN TRIGGER|black & GREEN / WHITE |5wi|horns in front of radiator  |
|           WIPERS|pink & blue/red     |+  |wiper motor                 |
|  LF WINDOW UP/DN|RED / green - green   |   |LF window motor             |
|  RF WINDOW UP/DN|RED / green - green   |   |RF window motor             |
|  LR WINDOW UP/DN|red - green         |   |LR window motor             |
|  RR WINDOW UP/DN|red - green         |   |RR window motor             |
| SUN RF OPN/CLOSE|not recommended     |   |                            |
Notes:
NOTE:  This vehicle has an immobilizer system that needs to be bypassed when adding remote start.  Use DEI part number 555U.  *1 The parking lights are multiplex from the headlight switch to the Front Controller and the Luggage Room ECU. The control modules then output to each light individually. Better to use the hazard lights, it is orange (-) at the hazard switch or also at the driver side fusebox in a 10 pin plug facing the rear of the vehicle.  *2 The data link connector is under the steering column.  *3 Also found at the multi-display in the center of the dash.  *4 It is at the fusebox, in an 18 pin plug that faces the firewall.  *5 Unlock requires a double pulse.
csorb
Copper - Posts: 317
Posted: August 06, 2003 at 2:18 PM / IP Logged
Thanks a lot. I can't seem to find a factory disarm wire for this car. If you have any info I'd appreciate it. Thanks again
profuse007
Gold - Posts: 2,015
Posted: August 06, 2003 at 4:35 PM / IP Logged
please read it carefully, this is too nice of a car to mess with.
have fun buddy
Houston,TX
Posted: August 07, 2003 at 12:12 AM / IP Logged
Please read MORE carefully.
