2000 sunfire, alarm goes off after 20mins
Duston
Member - Posts: 42
Posted: August 16, 2003 at 8:59 AM / IP Logged
Hi this question is for a 2000 sunfire, with a Ultra Start 1250TL Alarm/Starter...
Any help with the gem shut down , wiring diagram would be great ( wiring the diodes ).   I have two diodes 1 amp , when i cut the factory wires do the wires going away from the door need to connect the other end of the diode?  Or only use the wires that go into the doors ?   Any help ,  thanks
Factory security systems suck!
Platinum - Posts: 12,488
Posted: August 16, 2003 at 10:06 AM / IP Logged
http://www.velocitymotorsport.com/images/install_notes/149.jpg
Use diagram one and relay isolate the wires as well as diode isolate them.
