1999 Dodge Grand Caravan
majorj13
Member - Posts: 12
Posted: August 31, 2003 at 9:13 PM / IP Logged
Have a 99 dodge Grand Caravan, Looking for a wiring guide to install a command start 290i. I have the guide for the cs290, Just need the vehicle wires especially the door locks.
MajorJ
ViperATC5
Copper - Posts: 202
Posted: September 01, 2003 at 5:46 AM / IP Logged
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|red                 |+ |ignition harness            |
|          STARTER|yellow              |+ |ignition harness            |
|        IGNITION|blue               |+ |ignition harness            |
| SECOND IGNITION|BLACK/ orange        |+ |ignition harness            |
|        ACCESSORY|BLACK/ white *1      |+ |ignition harness            |
|       POWER LOCK|WHITE/ green        |*2 |left plug at bottom of fuse |
|     POWER UNLOCK|same wire           |*2 |box under cover (1 of 3)    |
|       LOCK MOTOR|brown               |   |*3                          |
|     UNLOCK MOTOR|BLACK/ pink          |   |*3                          |
|    DISARM DEFEAT|violet/white        |   |*3                          |
| PARKING LIGHTS +|do NOT use          |   |                            |
| PARKING LIGHTS -|grn/wht or grn/red |   |at light switch *4          |
|       HEADLIGHTS|lt. GREEN/ orange    |- |at light switch             |
|     DOOR TRIGGER|BROWN / lt. green     |- |dome light on/off switch    |
| DOME SUPERVISION|BROWN / white        |- |dome light on/off switch    |
| TRUNK/HATCH PIN|tied in with doors |   |                            |
|        HOOD PIN|pink/black          |- |underhood light             |
| FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
| DISARM NO UNLOCK|see directfax #1081 |   |                            |
|       TACHOMETER|gray or gray/red    |   |ignition coil               |
|       BRAKE WIRE|WHITE/ tan           |+ |brake switch               |
|     HORN TRIGGER|gray/orange        |- |top right plug of fuse box |
|           WIPERS|pink/purple        |- |steering column             |
| LF WINDOW UP/DN|lt. green - white   |A |drivers door switch        |
| RF WINDOW UP/DN|brown - purple      |A |drivers kick panel          |
| LR WINDOW UP/DN|dk. blue - red      |A |drivers kick panel          |
| RR WINDOW UP/DN|gray - dk. green    |A |drivers kick panel          |
Notes:
*1 Not required for remote start. *2 Use relays and set up for negative trigger. Place a 4020 ohm resistor inline on the lock output, and a 665 ohm resistor inline on the unlock output. If you do not have a factory security system use a 1500 ohm for lock and a 250 ohm for unlock.   *3 The door lock motor wires are located in the top left plug at the relay/fuse box under the drivers side of the dash.   *4 If the van has auto lamps, see direct fax document #1080.
draasch
Gold - Posts: 2,172
Posted: September 01, 2003 at 7:44 PM / IP Logged
Make:   Dodge
Model: Caravan
Year:    1999-00
This Database Was Last Updated On:    6/9/03
Index #: 9512
Alarm
Constant 12 volts PINK/BLACK RED & PINK IGNITION SWITCH HARNESS
Ignition 12 volts D BLUE IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light BROWN / L GREEN (-) GRAY 36 PIN CONNECTOR AT FUSE BLOCK *
Trunk Pin Switch TAN/BLACK (-) 40 PIN NATURAL CONN. AT FUSE BLOCK
Parking Lamp BLACK / YELLOW (+) GRAY 36 PIN CONN. AT FUSE BLOCK **
Power Lock WHITE/ D GREEN BOTTOM OF JUNCTION BLOCK TWO #217
Power Unlock SINGLE WIRE SYSTEM CONNECTORS,ONE ON THE LEFT. ***
* BROWN / L GREEN (-) Wire Can Also Be Found At Headlight Switch. ** Also Found As BROWN / YELLOW (+) In GRAY 36 Pin Conn. Above Fuse Block. *** Single Wire Door Lock System, WHITE/ D GREEN Wire Requires Chassis Ground Thru A 1.5K Ohm Resistor To Lock And Chassis Ground Thru A 249 Ohm Resistor To Unlock
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
