Tach on 02 Dodge Ram
gatightlines
Member - Posts: 13
Posted: September 02, 2003 at 2:38 PM / IP Logged
Can someone give me some more info on this wire?  I have searched the site and only have found what color not to use.  I would like to find a connection under the dash if possible.  Also, If anyone has directech's document 239 or any other documents on this truck let me know.  I do not have access to DEI's site.
zargon
Copper - Posts: 186
Posted: September 02, 2003 at 5:00 PM / IP Logged
use pin 27 at the power control mod located on the passenger side firewall, although i think it is easier to go under the hood, you should be out there installing a hood pin also.
profuse007
Gold - Posts: 2,015
Posted: September 02, 2003 at 5:02 PM / IP Logged
have you try using the volt-sense instead of tach-sense. it may work on certain cars
Houston,TX
gatightlines
Member - Posts: 13
Posted: September 02, 2003 at 6:17 PM / IP Logged
It is remote starting fine now so I assume that it is using the volt sense.  I just thought that the tach hook-up was a better way to go.  I now have a problem with starting with the key.  The remote start is working though.
profuse007
Gold - Posts: 2,015
Posted: September 03, 2003 at 11:03 PM / IP Logged
is the immobilizer constantly being on or only on when remote start. that may cause interference when there is a double bypass on the immobilizer.
fyi:if youre using 555u,i have a buddy who got the immobilizer bypass on constantly and his key ending up being screwed.
Houston,TX
