factory alarm in 2002 accent
rojoone2
Posted: September 18, 2003 at 11:16 AM / IP Logged
Hello. I am from the Bahamas and recently came across a Hyundai accent that I had to install a Viper 55HFin to. It has a factory alarm.
Everything works fine eccept the remote start. I searched the web trying to find wire codes for this car, and have come to the conclusion that it has a transponder in the key.  HELP!....I need wire codes and the part number for transponder bypass...
autosound
Copper - Posts: 58
Posted: September 18, 2003 at 3:50 PM / IP Logged
It does have a transponder fitted ,,Cant help you with codes but in the U.K we dismantel the key and hot glue the transponder to the inside of the steering column close to the antenna loop,,,,,However i only reccomend this if you are wiring the immobilisation part of the alarm.......
