2001 mustang wiring diagram needed please
Welcome Guest :)
alexdesignz
Member -
Posted: July 16, 2002 at 1:56 PM / IP Logged
does anyone have this info
dan768
Copper -
Posted: July 16, 2002 at 7:00 PM / IP Logged
Yep,
Year(s): 99-02 | Make(s): Ford | Model(s): Mustang | As Of: 03/04/02 |
12 Volt (+) | 14ga. Yellow at ignition harness or 14ga. YELLOW /GREEN at R.K.E. above driver’s kick panel (connector faces forward) |
Ignition 1 | 12ga. RED / Green at ignition harness or 18ga. WHITE/ Green at R.K.E. in White connector |
Ignition 2 | 12ga. Gray / YELLOW at ignition harness |
Ignition 3 | 12ga. RED / Black at ignition harness |
Accessory 1 | 12ga. Gray / YELLOW at same or 14ga. Blue/Black at R.K.E. (connector faces firewall) |
Accessory 2 | 12ga. BLACK/ Green at ignition harness |
Starter | 14ga. WHITE/ Pink or Blue/Red at ignition harness |
Horn | 18ga. YELLOW /GREEN (-) at R.K.E. (connectors facing down) |
Tachometer | 18ga. Lt. GREEN / WHITE at P.C.M. in passenger’s kick panel |
Lights (+) | 18ga. Brown at R.K.E. |
Lights (-) | |
Brake Lights | 18ga. RED / Green (+) at brake pedal switch |
Door 1 | 18ga. Yellow/Black (-) (driver door) at R.K.E. (isolate to prevent false triggers) (for KS2040 installs) |
Door 2 | 18ga. Gray/Red (-) (passenger door) at same (isolate to prevent false trigger) (for KS2040 installs) |
Door 3 | |
Door 4 | |
Interior Lights | 18ga. BLACK/ White (+) at same (for KS4040 installs) |
Trunk/Hatch | 18ga. BROWN / White (-) at same (isolate from keyless entry module with diode, cathode faces rear of vehicle, tag rear half of wire) |
Hood Pin | |
Trunk Release | 18ga. Pink/Green (-) at same (motor wire is Violet / YELLOW in driver’s kick panel) |
Lock (switch) | 18ga. Lt. Green (+) at same |
Unlock (switch) | 18ga. Violet (+) at same |
Driver Unlock | |
Arm (key) | |
Disarm (key) | |
Arm Input | 16ga. Pink/Black (M) or RED / White (M) at R.K.E. |
Disarm Input 1 | 16ga. RED / Orange (M) at same |
Disarm Input 2 | 16ga. Pink/Orange (M) at same |
LF Window Up | | LR Window Up: |
LF Window Dn | | LR Window Dn: |
RF Window Up | | RR Window Up: |
RF Window Dn | | RR Window Dn: |
Additional Info | It may be necessary to also isolate trunk 12v (+) wire to prevent false triggers. At the R.K.E. find the 18ga. GREEN/ Red (+) wire and splice a diode in |
| | line with the cathode facing the rear of the vehicle. |
dan
Remember (there are no hard cars,some just take longer to install on then others)
alexdesignz
Member -
Posted: July 17, 2002 at 9:04 AM / IP Logged
Tuesday, April 28, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
