accord alarm problems
egchewy
Posted: October 13, 2003 at 2:04 AM / IP Logged
i am trying to install an alarm system in my 96 accord.
according to wiring diagrams that i've downloaded, the door lock/unlock wires are located above the fuse box.
the wires are supposed to be BLACK/ white and orange.
i can't seem to be able to find these wires for some reason.
the rest of the alarm has been set up and works fine.
also, the wires that supposedly run the keyless entry have three wires (red, green, and blue).
does anyone have any idea what that third wire is for?
draasch
Gold - Posts: 2,172
Posted: October 13, 2003 at 7:05 AM / IP Logged
Make:   Honda
Model: Accord
Year:    1996
This Database Was Last Updated On:    6/9/03
Index #: 7655
Alarm
Constant 12 volts WHITE IGNITION SWITCH HARNESS
Ignition 12 volts BLACK / YELLOW IGNITION SWITCH HARNESS
Starter BLACK/ WHITE IGNITION SWITCH HARNESS
Dome Light BLACK/ WHITE (-) 20 PIN GRAY CONN. BEHIND DR. DASH *
Trunk Pin Switch ORANGE (-) 20 PIN GRAY CONN. BEHIND DR. DASH *
Parking Lamp RED / BLACK (+) 18 PIN BLUE CONN. ABOVE FUSE BLOCK
Power Lock BLACK/ WHITE DRIVER KICK ** #201
Power Unlock ORANGE PANEL
* Door Trigger In Pin #5, Trunk Trigger In Pin #7 ** Door Lock Wires Found In Gray 3 Pin Connector (Gray 4 pin Conn. On Wagon) Above Fuse Block In Driver Kick Panel Taped To Harness With Blue Tape. #201- See Negative Pulse Door Lock Diagram.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
daniel2002p
Silver - Posts: 524
Posted: October 13, 2003 at 12:32 PM / IP Logged
If you pull back the carpet by the drivers kick, you will find a two wire harness that is taped to the huge harness with blue tape.  Those two wire are lock and unlock!
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
