Clifford alarm and actuators
rangerace
Posted: October 14, 2003 at 12:36 PM / IP Logged
I am trying to wire a 524F (5 wire) on both doors to a Clifford Concept 100.  The alarm shows 2 wires (+ or -) coming off the module.  I shows for lock the other for unlock, but with 5 wires on the actuator I am confused.
Thanks for your help!
daniel2002p
Silver - Posts: 524
Posted: October 14, 2003 at 1:16 PM / IP Logged
Get a 451m it will all make sense then.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
rangerace
Posted: October 14, 2003 at 1:20 PM / IP Logged
Ok, I will bite.  What's a 451m?
daniel2002p
Silver - Posts: 524
Posted: October 14, 2003 at 5:18 PM / IP Logged
it is a devoce made by directed that basically makes five wire door locks easier to hook up.  if you go to your local circuit city, best buy, or any store like that, they can give you the right stuff.  just ask for a dei 451m.  hope this helps
    1.8L VVT-i I-4
rangerace
Posted: October 14, 2003 at 9:48 PM / IP Logged
Ok, I am with you so far.  Each actuator has 5 wires, one on each door (WHITE/ blue/BROWN / GREEN/ black).  The 451m has 5 wires (WHITE/ GREEN/ violet/BROWN / blue).  can you help ?
