97 ford areostar remote start issues
nate_g24
Member - Posts: 13
Posted: October 18, 2003 at 2:56 AM / IP Logged
 having problems locating the starter wiring caused by cluster's of wires need help!!!
HamiltonAudio
Silver - Posts: 278
Posted: October 18, 2003 at 12:08 PM / IP Logged
it will be a larger (14ish) gauge wire in the same harness that you found all your ignition and heater wires in.  don't have my wiremagic here, and can't remember the colour.  simply use your DMM to probe the large gauge wires in that harness.  the one that shows +12V when cranking ONLY is your starter wire.
b
ck auto
Copper - Posts: 257
Posted: October 19, 2003 at 10:07 AM / IP Logged
ck auto
Copper - Posts: 257
Posted: October 19, 2003 at 10:10 AM / IP Logged
nate_g24
Member - Posts: 13
Posted: October 27, 2003 at 9:50 AM / IP Logged
acording to chiltons there's 2 start wires  white /wpink trace is my start  and then a red w/lt green is my run
Platinum - Posts: 12,488
Posted: October 27, 2003 at 10:08 AM / IP Logged
 12V|yellow              |+  |at steering column          |
|          STARTER|WHITE/ pink          |+  |at steering column          |
|         IGNITION|RED / green           |+  |at steering column          |
|        ACCESSORY|gray / YELLOW         |+  |at steering column          |
| SECOND ACCESSORY|BLACK/ lt. green     |+  |at steering column          |
