Remote Start add on
cles
Member - Posts: 12
Posted: October 30, 2003 at 12:53 PM / IP Logged
I just purchased a UNGO RS151 remote start for my car.  I have a UNGO security system already installed on the vehicle (1993 Grand Prix GTP).  My question is...do I have to hook up ALL the wiring from the remote start??  The door lock, hood switch, etc is already wired for the security system.  I was thinking I could just wire the auxillary from the secirity system to the remote start??
Cam
profuse007
Gold - Posts: 2,015
Posted: October 30, 2003 at 1:04 PM / IP Logged
addon usually never have lock/unlock wires, if so you have an stand-alone unit not an add-on.
so if you have an add-on which presume you do, then hook up all the wires for the addon RS like ign,starter,acc, tach.....
with the initiate wire or start wire, tie it to the auxilary output from the main unit.
Houston,TX
cles
Member - Posts: 12
Posted: October 30, 2003 at 1:11 PM / IP Logged
I guess I worded that wrong.  The remote start IS a stand alone system, not an add on.  Can I wire it as you said, even though it is a stand alone??  I expect all the buttons on the RS remote will not work if I wire it this way??
jrilla
Gold - Posts: 1,498
Posted: October 30, 2003 at 3:01 PM / IP Logged
You do not NEED to install the hood pin, but it is an important safety feature. If you dont hook something up, you are right, the tranmitter will not perform that operation. Do you want to use it as an addon or do you want to use both transmitters?
You need to install the brake, the parking lights if you want them to turn on, the Starter output (on the engine side of the starter kill relay), All the ignition and Accessory wires that you vehicle has, and the tach wire. Perhaps even a disarm wire if necessary. I would install the hood pin wire too.
it is much nicer to have one combo unit.
J Rilla
Owner/Installer
cles
Member - Posts: 12
Posted: October 31, 2003 at 3:39 PM / IP Logged
I've decided I will wire everything up.  That way I can use either transmitter, if I want.
Saturday, January 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
