caddy deville remote start
metz35
Copper - Posts: 458
Posted: November 02, 2003 at 8:56 PM / IP Logged
have a 2003 caddy deville in the shop for a remote start..... the problem i am having is the car starts runs for 3/4seconds and then shuts off....no brake wire connected...not a tach probelem.... dont know if i have the right ignition wires or such....the info i have is pink and white .. ignition 1 and 2.... brown and orange ....accesory 1 and 2 ...using part number dei 555u...any help will be greatly appreciated
NowYaKnow
Gold - Posts: 1,217
Posted: November 02, 2003 at 10:01 PM / IP Logged
Your wire info looks right from what I have so I will just throw out some random ideas. Have you tried remote starting with the key in the ignition to make sure it's not a bypass problem? Did you try disconnecting the parking lights to make sure they are not backfeeding somehow? Everything I see says to go to the battery for constant where are you picking up your power from? Aside from that just test the rest of the wires at the ignition harness to see if there's possibly an extra ignition wire you didn't fire up..Unfortunately that's all I got maybe someone else has a little more experience with these cars..Good luck let us know what it turns out to be!
Mike
whitey
Member - Posts: 49
Make sure the brown wire is being powered as a 2nd acc not ignition.  Is they key you are using in the 555u programed to the vehicle already or is it a blank key?  Just for fun try it on Voltage sensing instead of tach to see if it fires .  Other than that?????  try a viper 555g maybe.
jrilla
Gold - Posts: 1,498
Posted: November 02, 2003 at 10:14 PM / IP Logged
Yeah, like NowYaKnow mentioned, make sure you get power from the battery.
J Rilla
Owner/Installer
Monday, February 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
