wirring diagram 1999 Suzuki Grand Vitara
TinhFive
Member - Posts: 9
Posted: November 02, 2003 at 10:43 PM / IP Logged
Can any body help me with the wirring diagram for 1999 Suzuki Grand Vitara ? (alarm and starter). And can anybody tell me if it need the bypass for starter ?.  Thank you
profuse007
Gold - Posts: 2,015
Posted: November 02, 2003 at 10:47 PM / IP Logged
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|WHITE/ green        |+ |ignition harness            |
|          STARTER|blk/red or blk/yel |+ |ignition harness            |
|        IGNITION|BLACK/ blue          |+ |ignition harness            |
| SECOND IGNITION|blue/black          |+ |ignition harness            |
|        ACCESSORY|yellow/black        |+ |ignition harness            |
| SECOND ACCESSORY|blue *1             |+ |ignition harness            |
|       POWER LOCK|pink               |- |door lock controller *4     |
|     POWER UNLOCK|pink/green          |- |door lock controller *4     |
|       LOCK MOTOR|blue               |   |door lock controller *4     |
|     UNLOCK MOTOR|blue/red            |   |door lock controller *4     |
|    DISARM DEFEAT|no progressive unloc|   |                            |
| PARKING LIGHTS +|RED / yellow          |   |black plug at the fuse box |
| PARKING LIGHTS -|RED / blue            |   |headlight switch *2        |
|       HEADLIGHTS|gray/black          |- |headlight switch            |
|     DOOR TRIGGER|BLACK/ red           |- |wht plug at the fuse box *2 |
| DOME SUPERVISION|use door trigger    |   |                            |
| TRUNK/HATCH PIN|tied in w/ door     |   |                            |
|       TACHOMETER|brown               |   |instrument cluster or ECM *3|
|      SPEED SENSE|blue / YELLOW        |4 |instrument cluster or ECM *3|
|       BRAKE WIRE|GREEN / WHITE        |+ |brake pedal switch          |
Notes:
*1 Not required for remote start. *2 Also located at the keyless entry module, if equipped. The keyless entry module is located above the driver kick panel. *3 The ECM is located behind the glove box.    *4 The door lock controller is to the right of the brake pedal.
Houston,TX
TinhFive
Member - Posts: 9
Posted: November 02, 2003 at 11:00 PM / IP Logged
thanks alot
profuse007
Gold - Posts: 2,015
Posted: November 02, 2003 at 11:20 PM / IP Logged
no need for bypass
Houston,TX
Tuesday, February 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
