2002 honda crv door trigger
mustangpony69
Member - Posts: 18
Posted: November 04, 2003 at 4:43 PM / IP Logged
I need to know where the factory alarm module is located. I am putting auto start and alarm in and is says to tap lt/green and green red at factory alarm module. Please help!!!!
mustangpony69
Member - Posts: 18
Posted: November 04, 2003 at 4:44 PM / IP Logged
this is for a 2002 honda crv!
JWorm
Platinum - Posts: 2,208
Posted: November 04, 2003 at 8:25 PM / IP Logged
Look for the plug high up under the dash that is not plugged into anything. You don't need to remove any panels to see it...unless it has that black panel on the underside that is held in place with two plastics twist screws. Usually held to another wiring harness with blue tape. You can't miss it. Its got a green connector if I remember correctly.
