remore start 2001 Chevy Cavalier
MrMaaaan
Member - Posts: 14
Posted: November 06, 2003 at 4:04 PM / IP Logged
i need a Wiring Diagram for a 2001 Chevy Cavalier, for a remote start Install..
Vincent Torrez
draasch
Gold - Posts: 2,172
Posted: November 07, 2003 at 12:16 PM / IP Logged
Make:   Chevrolet
Model: Cavalier
Year:    2000-02
This Database Was Last Updated On:    6/9/03
Index #: 6800
Alarm
Constant 12 volts RED & RED IGNITION SWITCH HARNESS
Ignition 12 volts PINK IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light L GREEN/ BLACK (DR) & L BLUE (ALL DOORS) AT CONV. CENTER *
Trunk Pin Switch ORANGE / BLACK (-) AT LIGHT IN TRUNK
Parking Lamp BROWN (+) AT HEADLIGHT SWITCH
Power Lock L BLUE DRIVER KICK (W/O OEM KEYLESS) ** #203
Power Unlock WHITE PANEL (W/OEM KEYLESS) #202
* L GREEN/ BLACK (-) Covers Driver Door Only. L BLUE (-) Covers All Other Doors. Diode Isolation Needed, Cathode (Band) Side Of Diode Faces OEM Wires. Convenience Center Module Located Behind Driver Dash. ** Without OEM Keyless Door Lock Wires MUST Be Tested From PASSENGER Switch!! W/O OEM Keyless See Note #203 Reversal Rest At Ground Door Lock Diagram. With OEM Keyless See Note #202 Positive Pulse Door Lock Diagram.
Remote Start
Tach Signal WHITE AT POWERTRAIN CONTROL MODULE * #238
Ignition #2 ORANGE IGNITION SWITCH HARNESS (HEAT/AC)
Ignition #3 N/A
Accessory BROWN IGNITION SWITCH HARNESS
Neutral Safety NOT GROUNDING TYPE - OEM SWITCH OPENS STARTER CIRCUIT
Brake Light WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light L GREEN (+) AT SWITCH ON TRANSAXLE
Rear Window Defrost N/A TIMER BUILT INTO SWITCH
* 2.4L Engine Tach Wire Is WHITE At Powertrain Control Module (PCM). 2.2L Engine Tach Wire Is WHITE or ORANGE At PCM Or Ignition Control Module. Both Wires Are 2 Cylinder Signals Each. PCM On Both Located In Passenger Front Fender. Ignition Control Module On 2.2L Located On Rear Center Of Engine. #238- See G.M. Passlock II Diagram.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
