2003 expedition wiring chart
604customs
Member - Posts: 22
Posted: November 29, 2003 at 7:34 PM / IP Logged
could someone help!!
need wiring chart for 2003 ford expedition
thanks!!!
604
streetstyle
Member - Posts: 19
Posted: November 29, 2003 at 9:11 PM / IP Logged
Audiovox Tech Support 8622 FaxBack ID:
FORD EXPEDITION 2003 4DR SUV
Security Color Polarity Location
Battery LIGHT GREEN/ VIOLET (+) IGNITION SWITCH HARNESS
Ignition 1 DRK. BLUE/LIGHT GREEN (+) IGNITION SWITCH HARNESS
- Note IGN #1 WILL ACTIVATE HEATER CONTROLS
Starter 1 RED / LIGHT BLUE (+) IGNITION SWITCH HARNESS
All Door Trigger BLACK/ BLUE (+) DRIVERS KICK PANEL
Domelight Super BLACK/ BLUE (+) DRIVERS KICK PANEL
LF Latch BLACK / YELLOW (-) @ VEHICLE SECURITY MODULE
RF Latch BLACK/ PINK (-) @ VEHICLE SECURITY MODULE
LR Latch BLACK/ BLUE (-) @ VEHICLE SECURITY MODULE
RR Latch BLACK/ WHITE (-) @ VEHICLE SECURITY MODULE
Trunk Trigger WHITE/ VIOLET (-) @ VEHICLE SECURITY MODULE
Alarm Disarm SEE NOTES
- Note FACTORY ALARM WILL DISARM WHEN IT SEES A VALID PATS KEY AND IGN #1 ACTIVATED.
Alarm Arm SEE NOTES
Parking Lights BROWN (+) HEADLIGHT SWITCH HARNESS
Remote Start
Accessory 1 BLACK/ LIGHT GREEN (+) IGNITION SWITCH HARNESS
Anti-Theft Type TRANSPONDER
Key Sense BLACK/ PINK (+) STEERING COLUMN HARNESS
Tachometer LIGHT GREEN / WHITE (AC) PIN 35 OF 46 PIN CONN. @ PCM
Crankshaft Sensor DRK. BL;U (AC) PIN 30 OF 46 PIN CONN. @ PCM
Camshaft Sensor DRK. GREEN (AC) PIN 31 OF 46 PIN CONN. @ PCM
Speed Sense GRAY/BLACK (AC) @ PCM OR WIPER MOTER
Brake Lights GREEN (+) AT SWITCH
Reverse Lights BLACK/ PINK (+) DRIVER KICK PANEL, HARNESS TO REAR
Horn BLUE (-) STEERING COLUMN HARNESS
Doorlocks/Windows
Power Unlock PINK/GREEN (-) DR. SILL PLATE HARNESS OR VSM
PowerLock PINK / YELLOW (-) DR. SILL PLATE HARNESS OR VSM
Driver Mtr Unlock RED / ORANGE (REV) DRIVERS KICK PANEL OR VSM
Driver Mtr Lock PINK/BLACK (REV) DRIVERS KICK PANEL OR VSM
LF Window Up WHITE/ BLACK (REV) DR. DOOR WINDOW SWITCH
LF Window Dn TAN/LIGHT BLUE (REV) DR. DOOR WINDOW SWITCH
RF Window Up TAN/LIGHT BLUE (REV) DR. DOOR WINDOW SWITCH
RF Window Dn WHITE/ YELLOW (REV) DR. DOOR WINDOW SWITCH
LR Window Up YELLOW/LIGHT BLUE (REV) DR. DOOR WINDOW SWITCH
LR Window Dn GRAY/ORANGE (REV) DR. DOOR WINDOW SWITCH
RR Window Up RED / BLACK (REV) DR. DOOR WINDOW SWITCH
RR Window Dn YELLOW/BLACK (REV) DR. DOOR WINDOW SWITCH
Sunroof Open WHITE/ RED (REV) @ SUNROOF SWITCH
Sunroof Close TAN/RED (REV) @ SUNROOF SWITCH
Convenience
Headlights-Hi RED / YELLOW (+) @ HEAD LIGHT SWITCH
LF Pk Lt Bulb BROWN (+) @ PARKING LIGHT BULB
RF Pk Lt Bulb @ PARKING LIGHT BULB (+) BROWN
LR Pk Lt Bulb BROWN (+) @ PARKING LIGHT BULB
RR Pk Lt Bulb BROWN (+) @ PARKING LIGHT BULB
All Hazrd Lights SAME AS TURN SIGNALS
LF Hazrd Bulb LIGHT GREEN / WHITE (+) STEERING COLUMN
604customs
Member - Posts: 22
Posted: November 30, 2003 at 12:06 AM / IP Logged
thanks for the help!!
604
