wiring diagrams for gnd am and gnd prix
misterjimbo
Silver - Posts: 535
Posted: November 30, 2003 at 8:28 PM / IP Logged
they are both 2003. i need tech sheets for both of these thanks guys
draasch
Gold - Posts: 2,172
Posted: December 04, 2003 at 12:05 AM / IP Logged
Make:   Pontiac
Model: Grand Am
Year:    2003
This Database Was Last Updated On:    6/9/2003
Index #: 7289
Alarm
Constant 12 volts RED IGNITION SWITCH HARNESS
Ignition 12 volts PINK IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light YELLOW (-) DRIVERS KICK *
Trunk Pin Switch ORANGE / BLACK (-) DRIVERS KICK BODY HARNESS
Parking Lamp BROWN (+) AT LIGHT SWITCH HARNESS
Power Lock WHITE DRIVER KICK (See Tech)
Power Unlock SINGLE WIRE SYSTEM PANEL #217
* Opitional Door Triggers Located At Body Control Module Under Passenger Dash. L GREEN/ BLACK (-) Covers Driver Door, L BLUE (-) Covers All Other Doors. Diode Isolation Needed, Cathode (Band) Side Of Diode Faces OEM Wires. #217- See Single Wire Resistor Door Lock Diagram (See Tech)
Remote Start
Tach Signal VIO/WHT OR WHITE TOP OF ENGINE ON COIL
Ignition #2 GREEN IGNITION SWITCH HARNESS #238
Ignition #3
Accessory ORANGE IGNITION SWITCH HARNESS
Neutral Safety ORG/BLK (-) BEHIND DRIVER'S DASH LEFT OF COLUMN
Brake Light L BLUE (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light LT GREEN OR GRAY IN DRIVER'S KICK PANEL
Rear Window Defrost
#238 - See G.M. Passlok II Diagram. Pass Lock Wires YELLOW And BLACK/ WHITE (Has Been Reported As BLACK Instead
Doorlocks Are Found As A Single Wire System. A Negative Pusle On The WHITE Wire In The Driver Kick Panel Will Lock The Doors. A Negative Pulse Thru A 1.5K Ohm Resistor On The Same WHITE Wire Will Unlock The Doors.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
draasch
Gold - Posts: 2,172
Posted: December 04, 2003 at 12:07 AM / IP Logged
Make:   Pontiac
Model: Grand Am
Year:    2003
Index #: 7289
Alarm
Tach Signal VIOLET/WHITE IGNITION MODULE ON PASS SIDE OF ENGIN
Ignition #2 WHITE IGNITION SWITCH HARNESS #239
Ignition #3 BROWN IGNITION SWITCH HARNESS (HEAT/ AC)
Neutral Safety
Brake Light WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light L GREEN (+) IN DRIVER'S KICK PANEL
Rear Window Defrost
#239- See Immobilizer Bypass Diagram
Remote Start
Ignition #3
Rear Window Defrost
Make:   Pontiac
Model: Grand Prix
Year:    2003
Index #: 1928
Alarm
Dome Light RED / BLACK (-) DRIVERS KICK PANEL AT 2 PIN PLUG
Trunk Pin Switch RED / BLACK (-) BODY HARNESS IN DRIVERS KICK PANEL
Parking Lamp BROWN (+) AT HEADLIGHT SWITCH
Power Lock L BLUE DRIVERS KICK #201
Power Unlock WHITE PANEL
#201- See Negative Pulse Door Lock Diagram
Remote Start
Neutral Safety
Rear Window Defrost
Good Luck
David
Ace Security
813-376-9778
Tampa
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
