02 f150 disarm wire?
profuse007
Gold - Posts: 2,015
Posted: December 06, 2003 at 7:54 AM / IP Logged
02 f150 5.4L lariat
cant seem to find the disarm wire (GREEN/ purple)at the driver kick....theres only 4 small harness at the kick, cant find it......anyone know exactly where it is. could it be somewhere up higher on the kick....hurry!!!...., my buddy comin back on sunday and i need this last wire to finish the installation.
thanks
Houston,TX
Platinum - Posts: 12,488
Posted: December 06, 2003 at 9:42 AM / IP Logged
I have the DARK GREEN/ Violet (-) trigger for the wire. Are you looking for a plain green or the dark green ??
whiteshack
Member - Posts: 24
Posted: December 06, 2003 at 5:00 PM / IP Logged
i also have dr. green\purple
mecp certified installer
misterjimbo
Silver - Posts: 535
Posted: December 06, 2003 at 8:39 PM / IP Logged
try the light blue white at the fem module. it is inside the car along the firewall on the drivers side it is a white module with aluminum brackets. there are two lt blue whites use the one that is next to a black pink. this is a multi function wire. you can use it as a door trigger (-) and if you double pulse the unlock it will wake up the module and the locks will never go to sleep. i believe that it also shuts down the factory alarm. i am not 100% sure, i work at the second largest ford dealer in the country and have never ran into a factory alarm on an f 150
profuse007
Gold - Posts: 2,015
Posted: December 06, 2003 at 8:53 PM / IP Logged
thanks yall, ill take a shot and repost the result
Houston,TX
