2001 Toyota Sequoia alarm info
brianh
Silver - Posts: 518
Posted: December 09, 2003 at 5:11 PM / IP Logged
I am planing to install an alarm on this vehicle tommorrow. I have not done one of these and was wondering if anyone has any experience with this vehicle? I think that the door locks are the only tricky part of it(Muiltplex system) I know how to get around that. The ecu is in the driver door (right?) Any help that you could give me is much appreciated. Thanks in advance.
Brian
owner/installer
Sight & Sound Car Stereo
"all electronic equipment runs off of smoke, once you let it out, it stops working"
HamiltonAudio
Silver - Posts: 278
Posted: December 10, 2003 at 2:47 PM / IP Logged
Toyota
Sequoia
2001-2002
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
BLACK/ WHITE
IGNITION SWITCH HARNESS
Ignition  #1:
BLACK/ RED
IGNITION SWITCH HARNESS*
Ignition #2:
BLACK / YELLOW
Ignition  #3:
N/A
Accessory:
PINK
Brake  Light:
GREEN / WHITE
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
YELLOW /GREEN
AT ECM PIN B4 **
Parking Lights:
GREEN (+)
AT JUNCTION BLOCK ON PASSENGER SIDE AT ECM
Headlights:
OEM Alarm  Disarm:
RED / YELLOW (-)
INSIDE OF DRIVER'S DOOR
OEM Alarm  Arm:
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * This vehicle is equipped with a transponder immobilizer system. Use Universal Alarm Bypass Module part # 2x402 where X can be any number. ** ECM is located behind the glove box on passenger side of the vehicle.
Toyota
Sequoia
2001-2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
WHITE/ BLUE
Starter  Kill:
BLACK/ WHITE
Ignition  +12 Volts:
BLACK/ RED
Dome  Lights/Superv:
WHITE
AT BCM PIN B8***
OEM Horn:
WHITE/ RED (-)
DRIVER'S KICK PANEL
Power  Lock:
SEE NOTE ****
Power  Unlock:
SEE NOTE ****
Trunk  Release:
Alarm  Input Wire:
WHITE
AT BCM PIN B8***
Notes:
*** The BCM is located high on the drive's side underneath the dash. Test for correct wire. **** See Installation Note #212 Modern Toyota Door Locks Diagram.
profuse007
Gold - Posts: 2,015
Posted: December 10, 2003 at 6:15 PM / IP Logged
theres an old thread about this model, search for "sequoia".......
Houston,TX
