convert 1 (-) output to 2 (-) outputs
2chado
Member - Posts: 6
Posted: December 09, 2003 at 9:13 PM / IP Logged
i only have one negative output left on my keyless entry. i need to use that one output (-) and have 2(-) outputs, so when i hit it the first time it pushes actuator and when i hit it a second time it pulls it. i alread have relays set up to change polarity just dont have 2 outputs to engage and disengage.
please help
JWorm
Platinum - Posts: 2,208
Posted: December 09, 2003 at 9:23 PM / IP Logged
Give us more info, what keyless system do you have and what are you controlling with it?
StealthEs
Copper - Posts: 326
Posted: December 09, 2003 at 9:44 PM / IP Logged
do you have any extra acc channels? If so you could use one of then as you second output
Cris
2chado
Member - Posts: 6
Posted: December 09, 2003 at 9:53 PM / IP Logged
its a bulldog keyless entry used for my truck. It has lock, unlock, and trunk release. The only output left is trunk release. I'm using the trunk release negative output to control an linear actuator.
auex
Platinum - Posts: 5,041
Posted: December 09, 2003 at 10:31 PM / IP Logged
It should be easy. Using the diagram below, modify it with using limit switches and then when the actuator is in it will go out and when it is out it will go in.
convert 1 (-) output to 2 (-) outputs -- posted image.
You're going to need to come up with how to wire and adjust the outputs to your needs, but it should be simple to do if you know your relays.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
2chado
Member - Posts: 6
Posted: December 09, 2003 at 11:18 PM / IP Logged
thank you!! if i only use the first relay can i use just 2 outputs , # 87 and # 30 off relay 1 without the other three relays? also what kind of diode is that in fist picture
2chado
Member - Posts: 6
Posted: December 10, 2003 at 6:18 PM / IP Logged
Anyone know where to buy the PCB latching relay. single pole double throw. or an easier way to take the neg. pulse from the alarm unit and give me two seperate neg. pulses. because i only have one neg. output left for an actuator(and no i cant use something else in the car because this neg pulse is powering the actuator in my workshop.
Mr.Swifty
Member - Posts: 37
Posted: December 10, 2003 at 11:44 PM / IP Logged
well most linear actuators Ive used come with a limiting switch allready installed in them...but anyways look into a PAC TR7 module, this will make it possible for you to controll the linear actuator in and out, and you would be able to stop it wherever you like, all with one negative pulse.
2chado
Member - Posts: 6
Posted: December 13, 2003 at 11:35 AM / IP Logged
never mind found what i needed through altronix part # rbr1224 it takes a (-) or (+) pulse and gives you two constant outputs for only $20.00. hit once give it to you on one side, hit pulse again and get constant on other side.
2chado
Member - Posts: 6
Posted: December 13, 2003 at 12:11 PM / IP Logged
thanx anyway swifty
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
