Lincoln Navigator 2000
domiyork809
Member - Posts: 29
Posted: December 11, 2003 at 12:28 AM / IP Logged
 Hi,
 Installling an alarm in a Lincoln Navigator, everything its fine but the door locks, How do I connect diodes or relays to the door system, tried without them, did not work, locks acting up. Please help.
Thanking you in advance.
profuse007
Gold - Posts: 2,015
Posted: December 11, 2003 at 3:04 AM / IP Logged
this is the info i have and not much to the notes.
BTW, what brand is the unit?
|       POWER LOCK|pink / YELLOW        |- |keyless module *2           |
|     POWER UNLOCK|pink/green          |- |keyless module *2           |
note: *2 The keyless module is located high in the drivers kick against the firewall.
Houston,TX
domiyork809
Member - Posts: 29
Posted: December 11, 2003 at 4:43 AM / IP Logged
It is a K-9 unit.
Saturday, February 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
