Posted: December 14, 2003 at 12:39 PM / IP Logged
Posted: December 14, 2003 at 12:46 PM / IP Logged
Wednesday, April 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
If you are having trouble accessing it there is a note regarding it: In A Green 12 Pin Connector That Should Be Located On The Right Hand Side of the Fuse Box. To Remove The Box Unscrew The 10 mm Bolt And The Box Will Slide Down.
Or try: Parking lights Can Also Be Found As BLUE (-) At Headlight Switch Or Steering Column Harness.
Thats negative though!
