96 range rover remote start/keyless
streetstyle
Member - Posts: 19
Posted: December 16, 2003 at 2:05 PM / IP Logged
has anyone installed a remote start and keyless entry on one of these vehicles? i pulled up the audiovox tech information on it. first thing ive noticed is negative polarity igniton and acc wires?!?!!? what about doorlocks on this vehicle?  any info would be appreciated!!!!!!!!!!!!!!!!!
Geeque
Silver - Posts: 310
Posted: December 17, 2003 at 4:57 PM / IP Logged
See if this helps you, the d/l wires should be in drivers kick one wire.
Security-----------------------------------------------------------------Battery            BRN/LT GRN +  (+) UNDER DR DASH OR GO TO BATTERYIgnition           WHT  (-)      (-) IGNITION HARNESSStarter01          VIO/YEL   (-) (+) IGNITION HARNESSAllDoorTrigger     VIO/RED (-)   (-) AT BODY CONTROL MOD "BELOW PASS SEAT"TrunkTrigger       WHT      (-)  (-) AT BODY CONTROL MOD "BELOW PASS SEAT"FactoryAlarmDisarm BLU      (-)      OR BLU/RED PULSE DURING LOCKParkingLights      RED  (+)      (+) PLUG RIGHT OF STEERING COLUMN-----------------------------------------------------------------Remote Start-----------------------------------------------------------------Battery            BRN/LT GRN +  (+) UNDER DR DASH OR GO TO BATTERYIgnition           WHT  (-)      (-) IGNITION HARNESSIgnition02         +Ignition03         +Accessory01        WHT/PNK  (-)  (-) IGNITION HARNESSAccessory02        +Starter01          VIO/YEL   (-) (+) IGNITION HARNESSAntiTheftSystem    NONETach               WHT STRIPE    (-) DIS COIL PACK REAR OF ENG 2 CYL(INJ 1 CYParkingLights      RED  (+)      (+) PLUG RIGHT OF STEERING COLUMNBrakeLights        WHT/GRY (+)   (+) SWITCH ABOVE BRAKE PEDALHorn               VIO/BRN (-)       AT BODY CONTROL MOD "BELOW PASS SEAT"-----------------------------------------------------------------Doorlocks / Window-----------------------------------------------------------------PowerUnLock        YEL    (-)    (-)PowerLock          YEL    (-)    (-) OR YEL /RED   ONE WIRE LOCKS-----------------------------------------------------------------Convenience-----------------------------------------------------------------TrunkRelease                         MANUAL RELEASE-----------------------------------------------------------------Mobile Audio / Video-----------------------------------------------------------------Battery            BRN/LT GRN +  (+) UNDER DR DASH OR GO TO BATTERYAccessory01        WHT/PNK  (-)  (-) IGNITION HARNESSGround             -Amp                UNDER PASSENGER SEAT-----------------------------------------------------------------Control Modules----------------------------------------------------------------------------------------------------------------------------------
Note:Tune-Town makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Tune-Town disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
Gary Kline
MECP Master Technician
Sunday, February 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
