Ford door locks w/RS
yellovet
Posted: December 26, 2003 at 10:30 PM / IP Logged
When a Ford(2003 Focus, 2002 Escort) is running the remote door locks do not work by Ford design. Is there a easy way to bypass or reprogram???
HamiltonAudio
Silver - Posts: 278
Posted: December 27, 2003 at 7:40 AM / IP Logged
why not connect the keyless feature of the rs you installed, and forget the factory keyfob?
b
Platinum - Posts: 12,488
Posted: December 27, 2003 at 8:20 AM / IP Logged
If you are using an aftermarket system and the OEM door locks are still not operational under remote start , then you may have to go straight to the lock motors.
LOCK MOTOR--------------------yellow/black @ drivers kick panel
UNLOCK MOTOR----------------WHITE/ black @ drivers kick panel
