2000 Saturn SW Wagon factory alarm
SoundFX411
Copper - Posts: 153
Posted: December 30, 2003 at 7:12 PM / IP Logged
I would like to know if anyone knows where the factory alarm brain is located. I'm having a problem with the fuel pump and it looks like its the alarm doing it. I would like to disconnect the alarm to see if this is the problem.
auex
Platinum - Posts: 5,041
Posted: December 30, 2003 at 8:45 PM / IP Logged
Factory alarm would run through the bcm if it even has one. I would check under the dash to see if there is wiring there for a dealer add on alarm.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Wednesday, April 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
