Remote start on 2003 Intrepid
97titan
Member - Posts: 6
Posted: January 02, 2004 at 11:18 PM / IP Logged
I am going to install a remote start system on my '03 Intrepid. I got wire diagrams for this from Mr Install and it talks about the reader box and finding the sweet spot. Can someone give me more info as to getting this done so the remote start will work? Do I have to have a second key as well to make this work? If someone has any other helpful tips for this project I would really appreciate the advice. Thank you in advance.
Tom
dyer
Copper - Posts: 206
Posted: January 02, 2004 at 11:25 PM / IP Logged
i'm assuming that he is talking about tweaking a bypass module. You have to match the resistance. THis is assuming that your car requires a bypass module. Call a local shop, and find out if you need any external modules for a remote start.
Dyer
97titan
Member - Posts: 6
Posted: January 02, 2004 at 11:46 PM / IP Logged
I really need some info a little less technical. This is my first install. How do I match the resistance? According to the directions I have say that I do have a reader box.
dyer
Copper - Posts: 206
Posted: January 03, 2004 at 6:37 PM / IP Logged
I'm not even sure if you need to match the resistance. The following info is from designtech. It talks about needing a Universal Alarm Bypass Module (see notes at the bottom of "remote start info" ). try this one: electronic gift basket This one is nice because it does your door locks,parking lights, starter enable, panic, arming and disarming of factory security system, rear hatch and door status. Hate to tell you, but if you look at the **notes you'll see that you need a lot of resistors for your install otherwise. This will make your life so much easier. You didn't pick an easy one for your first install, but hey! this will make the next one seem like cake!!
_________________REMOTE START INFO_________________
Dodge
Intrepid
2003-2003
Remote Starter Wiring Colors and Notes
Start:
   Yellow (+)
Ignition switch harness
Ignition #1:
   Dk.Blue/White (+)
Ignition switch harness*
Ignition #2:
   GREEN/ Red (+)
Ignition #3:
Accessory:
   BLACK/ Orange (+)
Brake Light:
   WHITE/ Tan (+)
Brake pedal switch
Tach Signal:
Parking Lights:
   Yellow (-)
Headlight switch**
Headlights:
OEM Alarm Disarm:
   LtGREEN/ Orange (+)
Drivers kick panel door harness***
OEM Alarm Arm:
   Lt.GREEN/ Orange (+)
Diesel Glow Plug:
   N/A
Clutch Bypass Wire:
   N/A
Notes:
   * This vehicle may be equipped with a Transponder Theft System that can be identified by a gray ignition key. Use Universal Alarm Bypass Module part # 2x402 where X can be any number. **Parking lights are a negative trigger through a 110 ohm resistor. ***Arm requires a positive trigger through a 1.87k (1870) ohm resistor, this will also lock the doors. Disarm requires a positive trigger through a 680 ohm resistor.
_________________ALARM INFO_________________
Constant +12 Volts:
   Pink/Black or Red (+)
Starter Kill:
   Yellow (+)
Ignition +12 Volts:
   Dk.Blue/White (+)
Dome Lights/Superv:
OEM Horn:
   BLACK/ Red (-)
Steering column harness
Power Lock:
   WHITE/ Green (+)
Back of the fuse box****
Power Unlock:
   WHITE/ Green (+)
Trunk Release:
   BLACK/ White (+)
Release switch
Alarm Input Wire:
Notes:
****Lock requires a positive trigger through a 2.7k (2700) ohm resistor. Unlock requires a positive trigger through a 620 ohm resistor. See Note #211 Negative Trigger Single Wire Door Locks
Dyer
Alpine Guy
Platinum - Posts: 2,478
Posted: January 03, 2004 at 6:51 PM / IP Logged
you do indeed need a security bypass moduel.  You need it for remote starting so it tricks your car into thinking there is a key in the ignition..  I use bypass's made by Automobility, the one i use has a lock/unlock ,input/output, and a factory alarm arm/disarm, input/output, , , to program it you need 2 keys,  , , unlike other security bypass units where you need to place a key into the bypass box and leave it there.
97titan
Member - Posts: 6
Posted: January 06, 2004 at 7:16 PM / IP Logged
Thank you guys so much. I really appreciate the help. I didn't realize that the module was something I had to buy first. Now I will get that and a new key to do this install. Thanks a ton.
Tom
dyer
Copper - Posts: 206
Posted: January 07, 2004 at 6:41 PM / IP Logged
Let us know kow it turns out! Good Luck
Dyer
97titan
Member - Posts: 6
Posted: January 08, 2004 at 8:49 PM / IP Logged
I went to buy the resistors and am not sure which ones I need. I know what resistance is needed but I didn't know what the 1/4W, 1/8W, 1/2W and 1W. I'm not sure what I need or even if it matters. Any help on this. I will definitely let you know how it turns out. Thanks for all your help here.
Tom
a97titan@aol.com
