98 accord LX 4, CS-2013FM remote start
Mixophrenia
Member - Posts: 15
Posted: January 03, 2004 at 8:46 PM / IP Logged
i purchased the CS-2013FM system and i have intalled everything myself... i have a 98 honda accord LX 4 door 4 cyl...
when i hit the remote start, the car doesn't crank over, it just keeps cranking... i'm guessin the ignition is not properly connected...
i found that there are three parking light RED / black wires, one for the rears and one for each front... i connected the white parking lights wire to all three wires, but the lights don't work... should i connect it to just one location?
my lock button does not work... altho the automatic locks work from the remote... the locks only lock after a starter disable or after i activate and then deactivate the panic function... and then i have the option of unlocking it with my remote, which works fine... it just won't lock from the remote...
thanks for all your help,
Vitaliy
JWorm
Platinum - Posts: 2,208
Posted: January 04, 2004 at 12:18 AM / IP Logged
"when i hit the remote start, the car doesn't crank over, it just keeps cranking... i'm guessin the ignition is not properly connected..."
I'm guessing you didn't temporarily bypass the immobizer chip in the key. Try remote starting the car with the ignition in the key. Then read the section about keys in the owners manual that came with the car
"I found that there are three parking light RED / black wires, one for the rears and one for each front... i connected the white parking lights wire to all three wires, but the lights don't work... should i connect it to just one location?"
Use one...located on the backside of the drivers side fuse box.
"my lock button does not work... altho the automatic locks work from the remote... the locks only lock after a starter disable or after i activate and then deactivate the panic function... and then i have the option of unlocking it with my remote, which works fine... it just won't lock from the remote..."
What wires did you use for lock and unlock? Use BLACK/ white for lock and GREEN/ red for unlock on LX models without factory security. These wires are located in a two pin gray connector by the front of the drivers side fuse box.
I've done about 6 of these cars (98-02 are all the same) in the last week. Last one today took about an hour.
Mixophrenia
Member - Posts: 15
Posted: January 04, 2004 at 4:32 PM / IP Logged
i think i pretty much understand everything except one thing... i know i wired the locks right... i have a 2-way pager and it only has one key to lock/unlock... i don't think the unit is recognizing the lock command because everytime i hit the button on my 2-way, it keeps unlocking, and won't lock... but if i activate the panic function and then cancel it, the doors lock automatically and the alarm activates... then i use the button to unlock the car and disable the alarm, but then it won't lock back from the remote, just keeps unlocking...
draasch
Gold - Posts: 2,172
Posted: January 04, 2004 at 6:13 PM / IP Logged
Make:   Honda
Model: Accord
Year:    1994-95
This Database Was Last Updated On:    6/9/2003
Index #: 5339
Alarm
Constant 12 volts WHITE IGNITION SWITCH HARNESS(FUSED 50 AMP)
Ignition 12 volts BLACK / YELLOW IGNITION SWITCH HARNESS
Starter BLACK/ WHITE IGNITION SWITCH HARNESS
Dome Light BLACK/ WHITE/ SILVER (-) GRAY MOLEX TO RT. OF STEERING COLUMN
Trunk Pin Switch ORANGE (-) AT LIGHT
Parking Lamp RED / BLACK (+) ABOVE DRV KICK-20 PIN BLUE CONN PIN 6
Power Lock BLACK/ WHITE 2 PIN PLUG, TAPED TO WIRING
Power Unlock ORANGE HARN. ABOVE FUSE BOX #201
#201- See Negative Pulse Door Lock Diagram.
Remote Start
Tach Signal BLUE OR TAN/BLUE TACH TEST CONN.-DRV ENG COMPARTMENT
Ignition #2 YELLOW IGNITION SWITCH HARNESS
Ignition #3 N/A
Accessory WHITE/ BLACK IGNITION SWITCH HARNESS
Neutral Safety GREEN / WHITE (-) 12 PIN CONNECTOR AT GEAR SELECT SW.
Brake Light GREEN / WHITE (+) AT BRAKE LIGHT SWITCH
Reverse Light GREEN/ BLACK (+) 12 PIN CINNECTOR AT GEAR SELECT SW.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Bnluis
Silver - Posts: 578
Posted: January 04, 2004 at 6:19 PM / IP Logged
make sure that  u don't have you Ignition and power backwards, Also you car in a bypass for Remote stater. It has a transponder key.
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
Mixophrenia
Member - Posts: 15
Posted: January 04, 2004 at 10:05 PM / IP Logged
yeah i found a couple wiring diagrams for my car and i think i wired everything correctly... but it still won't lock from the remote... and the parking lights don't work... i spliced into the RED / black wire on the back of the drivers fuse box...
draasch
Gold - Posts: 2,172
Posted: January 05, 2004 at 9:05 AM / IP Logged
check the outputs from the alarm with a meter and make sure they are working.............
Good Luck
David
Ace Security
813-376-9778
Tampa
Mixophrenia
Member - Posts: 15
Posted: January 06, 2004 at 5:03 AM / IP Logged
i wish i had one... i think i'm gonna call their tech support line... thanks for all your help...
JWorm
Posted: January 06, 2004 at 8:23 AM / IP Logged
You hooked up an alarm/remote start without a meter? No wonder you're having problems.
Mixophrenia
Member - Posts: 15
Posted: January 06, 2004 at 10:26 AM / IP Logged
well i got the wiring diagrams... i didn't think i would need anything else...
