94 integra parking light problem
slowturtle
Posted: January 04, 2004 at 3:33 AM / IP Logged
- installed an aps-510a in 94 'integra today.  Tested arm/unarm, door lock/unlock, trunk/door pins, parking lights and everything seemed to worked.  when i cleaned up a bit i went back out to do another check.  i notice that my turn signal lights would not work, but they would only blink when i arm/disarm the car.  also i can't get into the programming mode to program the alarm.   any ideas? any help would be appreciate thanks!
draasch
Gold - Posts: 2,172
Posted: January 04, 2004 at 9:22 AM / IP Logged
Parking Lamp RED / BLACK (+) GREEN CONNECTOR AT FUSE BOX
make sure you tapped into the right wire for your parking lights....if you wanted to use your blinkers.....check your flasher...you might have shorted it out
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
