Security System Model
ramdattk
Posted: January 04, 2004 at 1:52 PM / IP Logged
Hi There,
I need some help in trying to locate a suitable manual for my security system.
I can only identify the units from serial numbers and fccid's as seen on the unit.
I have the following units:
Model: AU-93 window interface
Magnetic Shock Sensor: AU-84T
unknown unit S/N: 020050400001  -12 , FCC ID: ELV55AL736R, DOC/MDC: 342 K1059
Remote: FCC ID: BGAAPS2T, DOC/MDC: 342K1058
Potter & Brumfield: VF4-45F11
Siren & On/Off switch.
Please let me know if you can assist in documentation or any information on the above units, which will enable me to install it.
Regards
Kenty`
draasch
Gold - Posts: 2,172
Posted: January 04, 2004 at 3:04 PM / IP Logged
Magnetic Shock Sensor: AU-84T .
the above parts are from omega.......if you can call me and ill call you back so i pick up the cost of the call....sound like you have an omega unit, however there are some ???? that need to be answered to know for sure....
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Thursday, February 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
